freddyfruitbat
Mar 18, 2013Guide
Back-UPS ES550UK: setup with ReadyNAS Duo v2. (Powerchute?)
I've just invested in the above UPS to go with my ReadyNAS Duo, having just learned to my cost that to use a one without a UPS in place is a Bad Idea :x however, am struggling a bit to get it set up ...
Mar 19, 2013Guru - Experienced User
As far as I can see from the APC website, they only have powerchute for the x86 ReadyNAS.
I use a cyberpower UPS myself, but based on other posters the UPS should be visible to the NV+ NAS over the USB port. Though I haven't seen much on the v2.
Maybe try APC support?
Also, if other posters are using this UPS with the v2, maybe they can chime in.
