cshuttle's avatar
cshuttle
Follower
Dec 19, 2018
Backplane replacement?
I've got an Ultra 4, and it looks like slot 3 on the backplane has gone bad. Does anyone know the part number for this so I can go about sourcing it?
  • StephenB's avatar
    Unfortunately Netgear doesn't sell spare parts.
    • Sandshark's avatar
      Sandshark
      Sensei
      The backplane for the NV, NV+ (V1), NVX, Ultra4, Ultra4Plus, and Pro4 are interchangeable, but not available separately.  If you pick up a non-working unit that's got a different problem (bad power supply, for example), you could use its backplane. You could, of course, purchase a working machine for parts, but they tend to be listed for more than I think they are worth.
      But, frankly, you are better off buying a new NAS and selling yours for parts.  Having a working power supply, I think it'll sell.
      Some time ago, I picked up a used Ultra4 with a similar issue on two bays.  It had been dropped.  I created a working hybrid with an NVX (which cannot be converted to OS6) and the Ultra4 main board, and then could update to OS6.
ProSupport for Business
