Gearmeister
Dec 30, 2021Aspirant
Backup Failure during copy
During backup from W10 Machine to the ReadyNAS 214, I get a failure about five minutes into it. The backup but then stops with the log below as the result. Not sure what they permission issue. This is a backup of the C drive. I can do a copy from D drive with no problem on the same machine. Not sure what's going on with all the permissions. I truned off all the anti-virus software but get the same result. The credentials for access to the machine test out fine. Any help would be appreciated.
Vitals below.
Firmware 6.10.6
---log file contents---
Backup Job Name: HPW10Cdrive
Backup Job Type: Incremental
Protocol: cifs
Backup Source: [remote:cifs]///192.168.1.24/C
Backup Destination: [HPW10Cdrive]/
Backup Start Time: Thu Dec 30 2021 5:29:43 PM
Backup Finish Time: Thu Dec 30 2021 5:39:35 PM
Backup Status: Fail: Failure during copy.
Cannot read file 'DumpStack.log' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/DumpStack.log' (error: Permission denied)!
Cannot read file 'DumpStack.log.tmp' (error: Device or resource busy)!
Failed to copy file '/data/HPW10Cdrive/DumpStack.log.tmp' (error: Device or resource busy)!
Cannot read file 'Program Files/Bitdefender/Bitdefender Security/DomainsLeaks_v2.db' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/Program Files/Bitdefender/Bitdefender Security/DomainsLeaks_v2.db' (error: Permission denied)!
Cannot read file 'Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-21-2668375826-3106449030-4069653337-1001/ondemandal.xml' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-21-2668375826-3106449030-4069653337-1001/ondemandal.xml' (error: Permission denied)!
Cannot read file 'Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-21-2668375826-3106449030-4069653337-1002/ondemandal.xml' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-21-2668375826-3106449030-4069653337-1002/ondemandal.xml' (error: Permission denied)!
Cannot read file 'Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-32/ondemandal.xml' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/Program Files/Bitdefender/Bitdefender Security/ProfilesData/S-1-5-32/ondemandal.xml' (error: Permission denied)!
Cannot read file 'Program Files/Bitdefender/Bitdefender Security/ProfilesData/system/ondemandal.xml' (error: Permission denied)!
Failed to copy file '/data/HPW10Cdrive/Program Files/Bitdefender/Bitdefender Security/ProfilesData/system/ondemandal.xml' (error: Permission denied)!
etc.
Not all folders on the system drive can be backed up with SMB.
You could use Windows Backup (set to back up to the NAS). https://kb.netgear.com/24913/How-do-I-back-up-my-Windows-PC-to-a-ReadyNAS-OS-6-system-using-Windows-Backup-and-Restore
Personally I use Acronis TrueImage (which also can back up to a NAS network folder).
- GearmeisterAspirant
StephenB,
Thanks for ther reply. I'll give that a shot. :Plus, I've used Acronis in the past and found it to be very robust.
-G
