GPSIS_HQ
Aug 15, 2018Guide
Backup PC folder; Folder Backup Error
Hello, I am trying to setup a PC to ReadyNAS backup.
I get the attached error when I try to backup any folder on my laptop.
Marc_V
Aug 15, 2018NETGEAR Employee Retired
Hi GPSIS_HQ
Were it able to create a folder on ReadyCloud when you initiated the backup? Have you tried creating another on a different Workstation/PC?
What is the NAS firmware installed on your ReadyNAS?
Regards
GPSIS_HQ
Aug 23, 2018Guide
Marc_V wrote:
Hi GPSIS_HQ
Regards
Hello Marc_V,
Sorry for the delay in responding.
No there was no folder created on the NAS. The firmware version is 6.9.3
There is no other workstation available...this is a home setup; had no problem doing this 2 years ago.
I can access the NAS and read/write operations work fine.
I had a HD change in my laptop and reinstalled the ReadyCLOUD desktop client.
Since the folder names have changed from the previous HD, it cannot backup those folders as they no longer exist.
I need to create new PC backup folders for the new folders on the PC, then copy the files from the old folders [on the NAS] to the new PC Backup folders on the NAS, after that is done I would delete the older PC backup folders from the NAS.
- Marc_VSep 02, 2018NETGEAR Employee Retired
Hi GPSIS_HQ
"I need to create new PC backup folders for the new folders on the PC, then copy the files from the old folders [on the NAS] to the new PC Backup folders on the NAS, after that is done I would delete the older PC backup folders from the NAS."
Creating new folder would then be the best option here since you have changed HD and reinstalled your Operating system.
Regards
- InspiredMindsJan 24, 2019AspirantRN10200
I have this problem, same error message when I am trying to Back Up a folder from my PC so that it will auto sync. Doesnt matter what file I try to use to become a back up
