Orange_GT3
Oct 31, 2020Aspirant
Backup Plex configuration
I am moving my Plex server from my ReadyNAS Ultra 4+ to another, newer, more powerful NAS. I know what files and folders I need to copy across but when I go to set up a Backup job, I cannot selec...
- Nov 01, 2020
If you know how to run rsync from the linux command line (ssh), you could transfer the folder to the destination NAS w/o using a backup job.
Another option with ssh, is to copy the plexmediaserver folder into a share. Alternatively create a zip the folder in a share (which will copy over the network much faster).
You can also of course drag and drop to the destination. That will be slower, but doesn't require any knowledge of linux.
Nov 01, 2020Guru - Experienced User
Orange_GT3
Nov 01, 2020Aspirant
Thank you for those various options. I'm not skilled enough for the first two so will just go with Copy/Paste via my PC. I suspect it is not a huge amount of data but it will be tens of thousands of small files.
- StephenBNov 01, 2020Guru - Experienced User
Of course it will depend on the size of your media library. On my own NAS it is about ~150,000 files and ~6 GB.
You could run into some file permission issues with drag and drop. The instructions for zipping it via ssh are here: https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/Unable-to-access-PLEX-media-files-Permission-issue/m-p/1993822
- Orange_GT3Nov 01, 2020Aspirant
StephenB wrote:
Orange_GT3 wrote:I suspect it is not a huge amount of data but it will be tens of thousands of small files.
Thanks again StephenB. I set the copy/paste operation going last night and it has worked. Once I added the new library locations and followed the remaining steps that Plex give, the new server is up and running.
- Sep 19, 2018Retired_Member
