Lestrad
Jul 26, 2016Aspirant
Backup: Problem access another network driveBackup, Tips from other users
Hello everyone. I'm trying to use the Backup function of my NAS to copy a .rar file from a share on another network drive - a rather old Maxtor SSD - but I keep getting an error: "Unable to access r...
- Jul 26, 2016
That seems to have been it. With a folder instead of a file as the target, it works. Thanks a million.
I have to say that the error message "Unable to access remote path" isn't very helpful...
Jul 26, 2016Guru - Experienced User
The backup facility is intended for backing up folders - I suspect it doesn't work for individual files. Try putting work.rar in its own folder (mayber workrar), and then use //192.168.0.13 as the hostname, and sauvegarde/workrar as the source path. Note there is no / before sauvegarde (and use the correct slash direction, which is opposite from windows).
Lestrad
