brannodz
Oct 29, 2016Aspirant
Basic Use of ReadyNAS
OK, got new Firmware (6.5), and have whole house hardwired.
I orginally thought that I could use the ReadyNAS as the primary hard drive for storing family photos, videos, and docs. I'm finding that I can backup and sync folders from numerous types of computers, MAC OS, Windows 10, etc. No probablem accessessing remotely. Here's the question.
Can I use the ReadyNAS as the primary drive and can edit, safe, backup between right on the ReadyNAS ? All other computers have smaller hard drives, like 500GB whereas the readyans has nearly a free 3T. I'm thinking the ReadyNAS could be used, but when i edit a word doc it doesn't save and tries to save locally. If i have 1000GB of pictures, which clearly can't fit on one of the smaller computers to sync. Thoughts on how to fix this or othe rsolutions?
Real basic, but thanks!!!
- FramerVNETGEAR Employee Retired
Hi brannodz,
It might be best if you map the ReadyNAS share first.
How do I map a network drive in Windows?
Once done, you can just use the "Save As" option on your MS Office program and locate the mapped drive.
You can also change the default location where your files will be saved.
Since you have different platforms that you are going to be working on I will the rest to you but here is a sample of what I am telling you:
How to Change the Default Save Location and Local Files Folder in Word 2013
- brannodzAspirant
Framer, thanks for the thoughts. I'll start with mapping then review your link. Thanks again!
- SandsharkSensei
Unfortunately, there are still some programs around that will not show mapped drives in the open/save dialogs. Hopefully, you don't run into any.
If you do, using a symbolic link instead of drive mapping can be a solution. From a Windows command prompt, type mklink /? for the help on symbolic links.
Also remember that putting all your eggs in one basket makes a failure all the more costly, so make sure you have a backup method in place. A RAID device is a big step toward more reliability, but failures and physical loss can still occur.
