dgerson76
Jun 28, 2011Aspirant
Best DVR for use with ReadyNAS
Hi- I currently have a ReadyNas Duo, but am thinking about going to the Ultra2+. Either way, I'm looking for a low cost DVR solution that will allow me to record from cable or OTA, straight to the...
mdgm-ntgr
Jun 28, 2011NETGEAR Employee Retired
Well you'd need a device that will work with writing stuff to a network drive.
You can read about the TiVo integration here: How to archive and playback TiVo recordings to the ReadyNAS
If you look at firmware updates you'll see fixes have come in for issues people have had with the TiVo integration. It should work very well.
