ricjohns
Feb 22, 2017Aspirant
Bit-rot detected Error
Im limited in rnas experience & im getting this regular error for some time on one of my older nas's running OS6.6.1 is there a fix? bitrot is not enabled have tried returning to OS4 with same result...
- Feb 24, 2017
Ok, still running on the new beta firmware you suggested, I removed the 2x 2TB compatable nas hdd's from ultra2 replaced them with one brand new 2TB hdd, formated, setup nas then I rsync'd a share (98gb) from one of the Rn31200 to the ultra 2, Bingo!! no errors!! restarted a few times, rebooted a few times, still no BitRot errors, rsync another full share (450Gb) over hopefully when that finishes I get no errors it will be solved.
mdgm-ntgr
Feb 22, 2017NETGEAR Employee Retired
That's very odd.
Which services are you running?
Do you have any apps installed?
- ricjohnsFeb 22, 2017Aspirant
Nothing on the nas except some mp4s & mkv files backed up from my main nas & 1 app "Plex" but it's allways toggled Off (not used)
services: SMB, Rsync, UPnP, HTTP, HTTPS, ReadyDLNA
