ricjohns
Feb 22, 2017Aspirant
Bit-rot detected Error
Im limited in rnas experience & im getting this regular error for some time on one of my older nas's running OS6.6.1 is there a fix? bitrot is not enabled have tried returning to OS4 with same result...
- Feb 24, 2017
Ok, still running on the new beta firmware you suggested, I removed the 2x 2TB compatable nas hdd's from ultra2 replaced them with one brand new 2TB hdd, formated, setup nas then I rsync'd a share (98gb) from one of the Rn31200 to the ultra 2, Bingo!! no errors!! restarted a few times, rebooted a few times, still no BitRot errors, rsync another full share (450Gb) over hopefully when that finishes I get no errors it will be solved.
ricjohns
this is the last few logs since I did the update:
Thu Feb 23 2017 14:28:47
Volume: Bit rot has detected an error within //var/log/frontview/status.log and cannot correct the error.
Thu Feb 23 2017 14:28:46
System: ReadyNASOS background service started.
Thu Feb 23 2017 14:27:37
System: The system is rebooting.
Thu Feb 23 2017 14:26:53
Thu Feb 23 2017 14:26:51
System: Firmware was upgraded to 6.7.0-T158.
aalexandrebeta
Feb 23, 2017Master
The 6.6.1 FW is really painfull!
- ricjohnsFeb 23, 2017Aspirant
6.6.1 working perfect on 2x RN31200 Readynas & 1 other Rnas ultra 2, the Error doesn't seem to be a problem but it is an error everytime i reboot etc.. so i'd lke to sort it after 6mths of trying.
