diealpen
Jan 25, 2012Aspirant
BitTorrent Add-On and Netgear WNDR4500 Router!?
Dear all! I have a problem with my Torrent!! Can someone help me, please? I replaced my old Netgear ProSafe Gigabit Router and Accesspoint with the new Netgear WNDR4500 WLAN-Router. Since that da...
JarnoG
Jan 25, 2012Guide
It can be a couple different points:
- Your NAS has some old network settings that happened to work with your old router, but doesn't work anymore with your new router. This can, for instance, be a static IP address, dns-settings, etc. This also means that your NAS will have no other connection to the internet either. You can check the settings in FrontView->Network->Interfaces. In most cases, "Speed/duplex mode" and "IPv6 assignment" should be set to auto. "IPv4 assignment" should be "Use value from DHCP server".
- You have to open the port that the bittorrent-add-on uses for its connections on your router. I've got no idea what this port number is, but you can probably find it somewhere in the settings of either the add-on or in the port-forwarding-settings of your old router. If the bittorrent add-on supports upnp, you can turn it on and it will automatically do the port forwarding settings on your router if it has upnp enabled as well.
