winchesterstoke
Feb 15, 2017Aspirant
Blue Flashing Night to NAS
I have a NAS RN10200 (which I got second hand). I've put a 2 and a 3 Tb disk in and tried to start the NAS... The blue light comes on but then after a short while now flashed continually? The sec...
jak0lantash
Feb 28, 2017Mentor
Imo, the best solution here is to aggregate both HDDs into a single JBOD volume. It's the best compromise.
Feb 28, 2017Guru - Experienced User
I didn't suggest that because the current manual says that isn't possible - pages 24 and 25 "JBOD is available only for volumes consisting of one disk"
The manual certainly has some mistakes though, and if the system lets you do it, you could give it a try.
