winchesterstoke
Feb 15, 2017Aspirant
Blue Flashing Night to NAS
I have a NAS RN10200 (which I got second hand). I've put a 2 and a 3 Tb disk in and tried to start the NAS... The blue light comes on but then after a short while now flashed continually? The sec...
jak0lantash
Mar 01, 2017Mentor
(Unless regression in 6.7.0)
If the user manual says that, then the user manual needs to be updated ^^
In Flex-RAID, you can indeed aggregate several disks into a single volume.
Technically, it just makes several BTRFS devices inside the same BTRFS volume.
+ no loss in volume capacity
+ it's possible to use disks of mixed capacity
+ single volume is more convenient to manage
- no redundancy
- no redundancy
- StephenBMar 01, 2017Guru - Experienced User
jak0lantash wrote:
If the user manual says that, then the user manual needs to be updated ^^It certainly does say it.
- SkywalkerMar 01, 2017NETGEAR Expert
The manual is technically correct. You can only create a JBOD volume with one disk. But once it's created, you can expand it with another single-disk JBOD component in Flex-RAID mode.
- Retired_MemberMar 01, 2017
