Comdiv1
Dec 08, 2016Tutor
bonding adapters with adaptive load balancing causing IP conflict ?
I don’t think this is really a problem more of a question and sanity check. I have bonded the adapters on my readynas with the Adaptive Load Balancing. All has went well and to be honest i no...
Dec 08, 2016Guru - Experienced User
If you have LACP you should use that instead.
