gpwolfe's avatar
gpwolfe
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings,
I just wanted to say that the pro (rndp6000) works w/4GB DIMMs.
Specifically, at least, these:
DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K
Frontview shows:
Firmware: RAIDiator 4.2.15
Memory: 8064 MB [6-6-6-18 DDR2]
I booted the thing just to see if it'd recognize any of it and grab some logs. Now it's running the memory test. I'll let that go overnight.
I was reticent to try it as no one else on here seemed to think it would work. I looked up the stats on the Q963 controller and ran a few information gathering tools like:
    dmidecode
    hwinfo
    decode-dimms (After building and inserting the eeprom module)
    lshw
And after seeing this:
Memory Controller Information
Error Detecting Method: 64-bit ECC
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 16384 MB
Supported Speeds:
Other
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 4
0x0009
0x000A
0x000B
0x000C
Enabled Error Correcting Capabilities:
None
I figured since it claims to support 4GB modules it was worth a shot.
Here's the 'meat' from decode-dimms with the new memory installed.
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0050
Guessing DIMM is in bank 1
---=== SPD EEPROM Information ===---
EEPROM Checksum of bytes 0-62 OK (0x34)
# of bytes written to SDRAM EEPROM 128
Total number of bytes in EEPROM 256
Fundamental Memory type DDR2 SDRAM
SPD Revision 1.2
---=== Memory Characteristics ===---
Maximum module speed 1600MHz (PC12800)
Size 4096 MB
tCL-tRCD-tRP-tRAS 6-6-6-18
Supported CAS Latencies 6, 5, 4
Minimum Cycle Time (CAS 6) 2.5 ns
Maximum Access Time (CAS 6) 0.4 ns
Minimum Cycle Time (CAS 5) 3 ns
Maximum Access Time (CAS 5) 0.45 ns
Minimum Cycle Time (CAS 4) 3.75 ns
Maximum Access Time (CAS 4) 0.5 ns
---=== Manufacturing Information ===---
Manufacturer Patriot Memory
Manufacturing Location Code 0x02
Part Number PSD24G8002
Manufacturing Date 2010-W38
Assembly Serial Number 0xB2151B28
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0052
Guessing DIMM is in bank 3
SPD Revision 1.2
Size 4096 MB
Assembly Serial Number 0xC9131B28
Here's
hwinfo --memory
output:
01: None 00.0: 10102 Main Memory
[Created at memory.61]
Unique ID: rdCR.CxwsZFjVASF
Hardware Class: memory
Model: "Main Memory"
Memory Range: 0x00000000-0x1f3791fff (rw)
Memory Size: 8 GB
Config Status: cfg=new, avail=yes, need=no, active=unknown
Not certain what else anyone might want for added 'warm and fuzziness' to take the plunge.
On another note, the corsair XMS2 twin2x4096-6400c5c did not work for me contrary to many other posts claiming they do. I will qualify that a bit further by stating that I could not get either DIMM to boot in the first socket. The one closest to the cpu. If I put one in the other socket and nothing in the one closest to the cpu it booted fine. If I left the 1GB stock in its shipped socket (closest to the cpu) and put one of the corsair modules in other socket it would boot and show ~3GB - 128MB (shared video ram reservation?).
In any case I robbed some memory out of my son's machine. A pair of supertalent T8UB2GC5 modules also DDR2-800 PC6400. They show up as [4-5-5-15 DDR2] in frontview.
I hope that's helpful.
Thanks,
--Gary
