deko220
Aug 18, 2011Aspirant
Bug in ReadyNas Frontview
Can this please be corrected in the next release?
chirpa
Aug 18, 2011Luminary
LDAP is not used.
Until the IP validation can be fixed with a new release, the Config Backup method is okay to use. I can create a restore zip file for you, that only contains the new DNS nameserver settings if you like.
Once the DNS is updated for your network structure, using the Security>Security Mode page to join to the DC should go smooth.
