Lucha
Feb 24, 2017Aspirant
Can access my admin page
I change the password and did not click the recovery password setup so changed password and now i cant get to the admin page is
Lucha
Feb 27, 2017Aspirant
If i do the os reinstall will it wipe out all my files on the drive??
How do i do that reinstall??
Feb 27, 2017Guru - Experienced User
No. It will reset the network configuration to use dhcp, and reset the admin password to password. Other settings and data should not be affected.
Page 19-20 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Be careful not to do a factory default, that will destroy your data.
- ralucMar 30, 2017Aspirant
i did the os reinstall on my system now i cant connect i checked and its healthy
i found my ip address but whats SUBNET MASK AND GATEWAY?????
its asking for that info
