Lucha
Feb 24, 2017Aspirant
Can access my admin page
I change the password and did not click the recovery password setup so changed password and now i cant get to the admin page is
Feb 27, 2017Guru - Experienced User
Lucha wrote:
If i do the os reinstall will it wipe out all my files on the drive??
No. It will reset the network configuration to use dhcp, and reset the admin password to password. Other settings and data should not be affected.
How do i do that reinstall??
Page 19-20 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Be careful not to do a factory default, that will destroy your data.
raluc
Mar 30, 2017Aspirant
i did the os reinstall on my system now i cant connect i checked and its healthy
i found my ip address but whats SUBNET MASK AND GATEWAY?????
its asking for that info
