Quincy999
Aug 26, 2024Aspirant
Can i connect the readynas104 to two different routers each on their own network
Hi, I have an old readynas104 that has served me well. I have now just got a second fibre connection to my house. One fibre connection for kids and another for business. The readynas has two ethernet...
- Aug 27, 2024
Quincy999 wrote:
i had one as 192.168.1.11 and the other as 192.168.1.111,So both routers are using the same LAN subnet - using 192.168.1.x addresses. That won't work. You need to change one of them to something else - 10.0.0.x is a good option (and is also reserved for this purpose).
If you have configured any static IP addresses, switch them back to DHCP before you do make this change.
Static addresses in general are a bad idea, it is better to use DHCP in the client devices, and reserve IP addresses in the router for any devices that need a fixed IP address.
Quincy999
Aug 27, 2024Aspirant
i had one as 192.168.1.11 and the other as 192.168.1.111, but this did not work. When I remove the ethernet from the network where it works then the other one starts working. It may just be a problem with my device. Thanks for the reply.
Aug 27, 2024Guru - Experienced User
- Quincy999Aug 27, 2024AspirantAh right, i get what you are saying. I will make the changes after I finish work and see if it works. Thank you very much for your help.
