miogpsrocks
Dec 09, 2018Tutor
Can I install Plex on my readynas? Firmware 6.9.2 readynas Pro
Shoudl this be in the app store on the unit itself or does it take more work to install this?
Are there any instructions ...
Marc_V
Dec 09, 2018NETGEAR Employee Retired
Hi miogpsrocks
You should be able to install Plex Media Server on your Pro 6 running OS 6 firmware. You just need to go to https://www.plex.tv/media-server-downloads/ choose NETGEAR as platform and select Intel 6.x.
There is also a guide which you can check here
Hope this helps!
Regards
