GereonF
Oct 27, 2011Aspirant
Can I move drives from a NV to a NV+?
My ReadyNAS NV is not responding to the power button (no lights at all). I also own a NV+ which is working fine. Can I put the drives from the NV into the NV+ so I can retrieve the latest data?
mdgm-ntgr
Oct 28, 2011NETGEAR Employee Retired
Depending what region you are in, if the serial is in the range, NetGear has been known to replace the PSU even though the unit is out of warranty. In the US they have been known to do this. You may wish to give NetGear a call.
