Ghostface
Sep 26, 2011Aspirant
Can I put my ReadyNAS hard drive into a D Link NAS?
Basically my readynas died and I want to get access to my files. My wife has a D Link nas at work, can i pop my hard drive in and access it? I've read that they use the same filesystem but will the...
mdgm-ntgr
Sep 26, 2011NETGEAR Employee Retired
The drive won't be able to be read and you'd risk the disk being wiped. Don't do it.
The ReadyNAS Duo has a 3 year warranty. I'd suggest giving NetGear support a call.
If all else fails you can try recovering data using a PC: Mounting Sparc-based ReadyNAS Drives in x86-based Linux
