Royalblue
Mar 13, 2024Tutor
Can I read a readynas drive on my PC?
Hi, I have a readynas 104 with 4 x 1tb drives inside. I have been having problems with booting the readynas after getting a no ip address error which I couldn't resolve. Is there any way ...
Mar 14, 2024Guru - Experienced User
How did you try to resolve it? Was RAIDar able to find the NAS?
What is happening when you try to boot the NAS?
Royalblue wrote:
Is there any way I can read the files on each of the drives
No, because the files are spread across all the drives (this is called striping).
You'd need to connect at least three of them to the PC, using either SATA or USB adapter/docks
Royalblue wrote:
I have a sata to usb attachment which connects the drives and they show up in 'disk management' with 3 partitions but each one shows that it has 927gb of free space. (image below, disk 1 being the drive from the NAS)
No, that is not free space. Windows is showing all the partitions as "free space" because it does not recognize the file format.
- Partition 1 is the OS partition (linux and the NAS application)
- Partition 2 is for swap
- Partition 3 is your data volume
Royalblue wrote:
Is there any way I can read the files on each of the drives and transfer them to a windows laptop?
If you know linux (I'm guessing not), then you can boot up the PC under linux and manually mount the volume.
Another option (which costs) is to purchase RAID recovery software that supports the BTRFS file system. ReclaiMe is an option that several folks here have used with success.
Either way you will need a way to connect all the disks.
Royalblue
Mar 14, 2024Tutor
Hi Stephen,
I wasn't able to resolve the IP address issue, I checked the Ethernet cables etc. I have RAIDar installed but it wasn't able to find the NAS.
My router had the NAS showing as connected but unidentified.
When I try to boot it gets stuck at 38% (Maybe I should try to reboot again?)
I have the ReclaiMe installed as a demo, I only have one SATA dock at the moment though.
One more question how do I now which RAID number I have set up?
Many thanks,
Andrew.
- StephenBMar 14, 2024Guru - Experienced User
Which means the ethernet is working.
But it didn't give it an IP address? That would be odd, unless the router was set up to block connections by default.
Did you set up the NAS to use a static address? And then get a new router?
Did you try switching to the second NIC?
FWIW, it sounds like your NAS is working, but something else is wrong with your network setup.
Are you using four 1 TB drives? If so, default setup is RAID-5.
As I said, files (and metadata) are spread over all the disks. That means that generally part of a file will be on one disk, the rest of it will be on other disks.
- RoyalblueMar 14, 2024Tutor
Not sure about the static address but I have had several routers since it was set up.
How would I switch to the 2nd NIC?
Thank you.
I shall try and reboot again, how long should a reboot take?
Many thanks.
- SandsharkMar 14, 2024Sensei - Experienced User
I agree with StephenB that the Ethernet hardware is likely working. But since you can't boot, it is possible the issue is with the OS. Try removing all the drives (labeling them if you pull them all the way out so you can put them back in the same order) and see if it then gets an IP address. If it does, the problem is with the OS on the NAS.
