Royalblue
Mar 13, 2024Tutor
Can I read a readynas drive on my PC?
Hi, I have a readynas 104 with 4 x 1tb drives inside. I have been having problems with booting the readynas after getting a no ip address error which I couldn't resolve. Is there any way ...
Mar 21, 2024Guru - Experienced User
Royalblue wrote:
Or should I try the method highlighted by Sandshark and mount in a virtual NAS?
If you can create images of the drives on your PC, then Sandshark's method would be the safest path - because you would be leaving the drives themselves intact. So even if you made a mistake, you wouldn't be risking your data.
After the data is offloaded, we can shift back to the reset issue.
Royalblue wrote:
I tried a new power adapter but that didn't make any difference.
FWIW, I was thinking that might resolve the ATA errors. But I did not expect the volume to mount, as the RAID is almost certainly out of sync. If you send me a fresh set of logs, I can see if the ATA errors are still happening with the new adapter.
Royalblue
Mar 24, 2024Tutor
Hi,
<<<<<FWIW, I was thinking that might resolve the ATA errors. But I did not expect the volume to mount, as the RAID is almost certainly out of sync. If you send me a fresh set of logs, I can see if the ATA errors are still happening with the new adapter>>>>
Just tried to get a fresh set of logs but RAIDar didn't find the NAS for some reason. I may give that a go again later, although I did get a alert from my Gmail which said:
'Detected increasing ATA error count: [52] on disk 2 (Internal) [TOSHIBA DT01ACA100, 54NW90MNS] 14 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.'
So maybe the new adaptor didn't help?
