GeoffClout
Mar 07, 2012Follower
Can I use a Netgear RND2000 with one drive and...
I want to buy a Netgear RND2000-100UKS ReadyNAS Duo 2-BAY RND2000-100UKS and add just one Western Digital Caviar Green 2TB SATA 6 Gb/s 64MB 3.5 inch Hard Drive WD20EARX Can I later add an identical...
mdgm-ntgr
Mar 07, 2012NETGEAR Employee Retired
GeoffClout wrote: I want to buy a Netgear RND2000-100UKS ReadyNAS Duo 2-BAY RND2000-100UKS and add just one Western Digital Caviar Green 2TB SATA 6 Gb/s 64MB 3.5 inch Hard Drive WD20EARX
Yes. Do note that the Duo v1 is a discontinued product. The new Duo v2 supports disks larger than 2TB in capacity. With the Duo v1 you are limited to using 2TB disks.
GeoffClout wrote:
Can I later add an identical disc and have it recognised as a raided disc.
Yes, using the default X-RAID this is what will happen.
