arun3456
Feb 21, 2022Aspirant
Can not access attached USB disk with ReadNAS212
Hi, I have attached 2 external USB disks to my ReadyNAS-212 NAS. However whenever I try to access them using Finder in my iMac, I get error message stating "The operation cant be completed because the...
arun3456
I can only see contends of USB_FLASH_6 in Finder (Mac). If I want to copy any file to USB_FLASH_6 using command+C, I cant do. Finder is asking for password (PFA the snapshot), and if I provide my Login credentials of Mac, it does not accept.
Feb 21, 2022Guru - Experienced User
What happens if you enter the admin credentials of the NAS?
I am thinking you have a permissions problem. There are two sets of permissions - network access and file permissions. Both need to be set up properly to allow access. One option is to look at these settings for a share on the internal drives, and match them on the two USB drives.
- arun3456Feb 21, 2022Aspirant
I get a message stating that I dont have permmission. Attached is the snapshot.
- StephenBFeb 21, 2022Guru - Experienced User
Match the permission settings in the NAS web ui ( https://nas-ip-address/admin ) - via the settings wheel for the shares on the shares page.
Reset the file permissions if you change them (using the control on the left of the screen). That will apply the changes to every file/folder in the share.
I could not get your solution. What will be the correct settings?
