NOROSORO
Oct 09, 2018Follower
Can not connect to my NetGear Ready NAS Duo V1 (RND2000)
Hello,
I'm new here.
I have some problems with mij NetGear Ready NAS DUO V1. I give my NAS a Factory reset. After reset the NAS has get a DHCP adres. I can ping this adres. But i cannot conne...
Oct 09, 2018Guru - Experienced User
You can't connect to the menu unless disks are installed and functioning. If you are doing initial setup (or a factory default), the system might still be setting up the RAID array. It generally will be non-responsive for a while when it is doing that.
Try using RAIDar on a PC, it should be able to discover your NAS and give you some basic status. https://kb.netgear.com/20684/ReadyNAS-Downloads
Also, there could be some information in the blinking leds. Here's the decoder ring:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
