davidr1
Dec 21, 2018Luminary
can not save configuration
OS 6.9.4, Linux 18.04, Firefox Quantum
Recently I decided to update my backed up settings configurations for the above drives.
I could not. I pressed Settings>Configuration Backup>Download configuration archive but each time I got a pop-up tab saying:
"Forbidden
You don't have permission to access /dbbroker on this server.
Apache/2.2.34 (Debian) Server at 192.168.1.7 Port 80"Any help please?
- Retired_Member
Hi davidr1, to just make sure, that your issue is not related to firefox in anyway, why not trying another browser (Chrome, Edge, Lunascape, ...) you might have at hand and see whether you are getting the same error.
Kind regards
Were you using admin, or some other account in the admin group?
Trying another browser is worth a try.
I'm not seeing this problem with 6.9.3 (using Chrome), so you could also try downgrading, saving the configuration, and then upgrading back to 6.9.4.
- SandsharkSensei
Have you enabled admin access through HTTP (rather than just HTTPS)? I find it odd that it's trying to access via Port 80, when it should be 443 for HTTPS. Maybe a bug when you have made that selection?
