Devius
Jan 23, 2020Aspirant
Can see ReadyNas on Raidar but cannot browse
Hello everybody, I recently changed my PC and stored a backup of my data on the ReadyNAS. Although it always worked perfectly fine with the previous PC, and also works fine with other devices (inclu...
- Jan 23, 2020
I solved the problem following this thread:
I don't know which one of the suggestions did it, because I did them all and only after I restarted the PC, Raidar started working properly.
Hope this can help someone else :)
Sandshark
Jan 23, 2020Sensei
What happens if you type \\192.168.1.41 into a Windows Explorer address bar (note, NOT Internet Explorer)?
