Tonkinite
Mar 11, 2017Luminary
Can subversion package be made to work on RN51600 with 6.6.x?
I've installed and uninstalled subversion many times, never seems to do anything. Discussions on the board suggest it can be fixed by using root ssh (which I won't do) and adding the missing WebDAV m...
FramerV
Mar 13, 2017NETGEAR Employee Retired
Hi Tonkinite,
Given that this is a 3rd party app, I do not think that someone from NETGEAR can help. You can contact the developer for assistance on your request.
Tonkinite
Mar 18, 2017Luminary
Actually, if the package is broken, Netgear should boot it off the availability list (and apparently should have aeons ago), this could put pressure on the developer.
I will try, but I'm sure others have also (yes?), and nothing has apparently happened in years. Maybe the developer is inactive, retired, whatever and should transfer responsibility to someone else.
It's been broken since I bought my RN516 in December 2013 (so at least 3 years).
