eton
Apr 28, 2020Luminary
Can you move disks between different models? Same CPU arch and OS
Can you move disks from one device to another of a different model, if both models share the same CPU architecture and ReadyNAS OS support, without data loss?
I am particularly interested in Intel based architectures.
For example can you move disks between RN312 and RN422?
Can you aslo move from any of them upp to a bigger model like RN 424?
- Marc_VNETGEAR Employee Retired
Yes, you can move disk from the same CPU and OS. You can even move from ARM to Intel based as long as they have the same OS versions without Data loss.
If moving from ARM to Intel based, only the Apps installed will have to be reinstalled to work with x86 models.
HTH
eton wrote:
That is great news. Moving between models is of course one of the key features, but I remember that it was a bit trickier with the older models, like SPARC.
If you mean migration from legacy NAS to OS-6, then it isn't actually possible. You can temporarily mount OS 4.2.x data volumes on X86 OS-6 NAS. You can also temporarily mount 4.1.x or 5.3.x data volumes on any OS-6 NAS, but that requires assistance from support.
That lets you offload data, but you then need to restore it from backup after you set up the OS 6 system.
But you can migrate between OS-6 models.
