mshallop1's avatar
mshallop1
Follower
Jan 17, 2014
cancel firmware update doesn't
Downloaded new fw update - got alert stating, basically, that device was in-use (it was), and was asked: are you sure you want to install? Clicked cancel. Installed anyway.
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What model ReadyNAS and what firmware version from/to. If you download your logs and extract the contents of the zip file what does initrd.log look like?
    What web browser and version are you using?
ProSupport for Business
