Plumiere
May 25, 2017Aspirant
Can'complete OS reinstall on my ReadyNAS Ultra 2
My ReadyNAS has been perfectly working up to now. After changing both 1 To HD on my device, OS reinstall doesn't perform any more. I've been waiting more than 36 hours but nothing happens. Both dis...
May 26, 2017Guru - Experienced User
I've been waiting more than 36 hours but nothing happens. Both disk LED remains lit.
DId you replace both disks at the same time?
What firmware are you running?
What status does RAIDar tell you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- PlumiereMay 26, 2017Aspirant
Hi,
Yes I replaced bith disks at the same time. Actually I needed old disks for another computer and I bought two brand new 1 To HD.
No idea about the firmware. Never updated, it should be the original one.
No status from RAIDar, device is not recognized (except when I do a disk check).
- StephenBMay 26, 2017Guru - Experienced User
Plumiere wrote:
Hi,
What disk models did you install?
Do you see the NAS in the list of attached devices shown in your router?
I suggest
- testing the disks with vendor tools in a PC (lifeguard for western digital, seatools for seagate)
- trying the factory install boot option shown on pages14-15 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
Then update the firmware (which requires that disks be installed).
Disks are Samsung HD103SJ (1 To / 7200 rpm). I'vec checked the disks, both are OK.
NAS is invisible.
I've tried firmware upgrading. It failed. The device doesn't shutdown after a time as mentionned in the guide. Only the powerswitch button LED is lit, not the four other LEDs.
Tried several different USB keys. Same result.
I think the firmware is corrupted.
- Jul 15, 2018Retired_Member
