happymanny1986
Nov 02, 2015Aspirant
Cannot Access ReadyNAS 2100
Sorry ahead of time about the incoming wall of text. I am using 9 ReadyNAS 2100s in a movie theater for content storage and playback. This is a common setup for movie theaters running Christie (b...
GregBergman
Feb 03, 2016Aspirant
I realize this post is old but i'll give it a try.
Christie has been using the standard Radiator builds for over a year now (currently RAIDiator –x86-V4.2.26). The build in question was an interim fix to a problem that Christie found in Radiator builds prior to 4.2.26 so Netgear made 4.2.26-TX until the problem was solved, then released 4.2.26. Also, Netgear 2100's that Christie uses are standard off the shelf units.
kohdee
Feb 03, 2016NETGEAR Expert
I looked into it further. We replaced the NIC driver for RN2100 in 4.2.26 going forward, so all new firmware since then should work with the Christie projectors.
I have since also released the RAIDiator 4.2 rebuild utiltiy. http://kb.netgear.com/app/answers/detail/a_id/30267 -- sorry it took me so long to get it out.
