AndySweden
Dec 30, 2018Aspirant
Cannot reset password readynas duo 2000
Cannot reset password on my old ReadyNas Duo 2000. I have followed all instructions and I think I got the OS reinstall to kick in. But after that I tried to click in Install from RaidAr, got the log...
- Dec 31, 2018
AndySweden wrote:
Cannot reset password on my old ReadyNas Duo 2000. I have followed all instructions and I think I got the OS reinstall to kick in. But after that I tried to click in Install from RaidAr, got the log in page from browser but cannot access with the default password. i.e user:admin and password: password.
Try using netgear1 as the password. That's the default for the original duo v1 (which is likely what you have). The labeling is confusing.
A Duo v1
- Has ReadyNAS Duo on the front panel
- Runs 4.1.x firmware
- Might have a v2 label on the back or bottom
A Duo v2
- Has ReadyNAS Duo v2 on the front panel
- Runs 5.3.x firmware
Dec 31, 2018Guru - Experienced User
A Duo v1
A Duo v2
AndySweden
Dec 31, 2018Aspirant
Thank you very much for quick response! It works :)
- StephenBDec 31, 2018Guru - Experienced User
I'm glad I could help.
