AndySweden's avatar
AndySweden
Cannot reset password readynas duo 2000
Cannot reset password on my old ReadyNas Duo 2000.  I have followed all instructions and I think I got the OS reinstall to kick in. But after that I tried to click in Install from RaidAr, got the log...
  • StephenB's avatar
    Dec 31, 2018
    AndySweden wrote:
    Cannot reset password on my old ReadyNas Duo 2000.  I have followed all instructions and I think I got the OS reinstall to kick in. But after that I tried to click in Install from RaidAr, got the log in page from browser but cannot access with the default password. i.e  user:admin and password:  password.
    Try using netgear1 as the password.  That's the default for the original duo v1 (which is likely what you have). The labeling is confusing.
    A Duo v1
    • Has ReadyNAS Duo on the front panel
    • Runs 4.1.x firmware
    • Might have a v2 label on the back or bottom
    A Duo v2
    • Has ReadyNAS Duo v2 on the front panel
    • Runs 5.3.x firmware
ProSupport for Business
