techjd
Mar 01, 2016Follower
Cannot set static IP address
I've connected the ReadyNAS to my network without a DHCP server and I am able to access it on the default IP address of 192.168.168.168. Everytime that I try to change it to static (192.168.101.33) ...
Mar 01, 2016Guru - Experienced User
Can you post the actual firmware version? (which would be 5.3.11 for a v2, and 4.1.14 for a v1). One reason is to confirm the platform.
JennC
Mar 01, 2016NETGEAR Employee Retired
Hello techjd,
Welcome to the community!
Also, how do you know that it is back to its default? Does it get any error message? Do you also change the default gateway?
Regards.
