eruditusfaber
Aug 27, 2016Aspirant
Can't Connect to the router (AP).
Hi! I've just bought the RN102 (used one) and i'm struggling to connect it. Power ON - led is on ACT - led is on Disk 1 - led is on But on the back LEDs in LAN port are off. I have ...
Aug 28, 2016Guru - Experienced User
You could try the factory reset procedure on page 15-16 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN%20OS%206%20Desktop%20HW%20UM_15Oct2013.pdf
But I fear you purchased a defective unit.
- BrianL2Aug 29, 2016NETGEAR Employee Retired
Hi eruditusfaber,
Welcome to the community!
Before you follow StephenB's suggestion, try to boot up your unit without drives (mark/label them once you remove them) and check if the LEDs of ReadyNAS LAN will lit up or it shows up on your network (RAIDar).
Kind regards,
BrianL
NETGEAR Community Team- eruditusfaberAug 29, 2016Aspirant
Hi BrianL,
When i boot up NAS without drive (i've got one) the power LED blinks (only this one in frone) and LAN LEDs are still off. And also i can't find it with RAIDar.
Any other ideas?
I have only one compatible HDD and i have some data on it so i have to wait with factory reset untill i get new HDD.
Best regards and thanks for any help,
Simon.
Hi eruditusfaber,
Does the data on your ReadyNAS important? Also, do you have a backup of it? Well, you can try to access it's boot menu and see if the unit can be set in telnet (techsupport) mode. If that won't work, the last thing you can try is to perform USB boot recovery.
Kind regards,
BrianL
