signetdesign
Mar 22, 2018Aspirant
Can't Factory Reset my ReadyNAS Duo
So I ran across this this ReadyNAS Duo (RND2110-100NAS) at work. The previous IT guy was fired and left no documentation behind and my RAIDar could not detect my NAS when I plugged it into the networ...
- Mar 22, 2018
If you pulled out the hard drive, hooked it up to your computer, and it was readable right away, then that's not a drive that was ever used in the ReadyNAS unless your computer runs Linux.
You cannot do a factory reset or boot without a drive installed. The unit boots from the drive(s) and a factory default re-initializes the drive(s) from the flash memory so it can boot from them. But you should be able to see the device in RAIDar without one, though you may need to use version 4.3.8 from /ReadyNAS-Downloads rather than 6.3. If it still doesn't show up, then as JohnCM_S said, it's possible the device is broken.
mdgm-ntgr
Mar 22, 2018NETGEAR Employee Retired
signetdesign wrote:
all the LED flash slow twice, then flash fast thrice.
That's the LED pattern to let you know the error that No disks have been detected, though we'd describe it has there being three quick blinks followed by the slow blinks. It's the number of slow blinks that indicates which error it is.
