egoff
Oct 24, 2012Aspirant
Can't get correct replacement part from support
I have a ReadyNAS 3100 under warranty, with a failing power supply. I've had a case open with Netgear support for 25 days. It took about 2 weeks for them to agree the power supply needed to be replace...
chirpa
Oct 24, 2012Luminary
I've pinged siigna to take a look. Whats your case number?
