sonnesoftgun
Jan 16, 2012Aspirant
Can't install add-ons after upgrade.
Hello Supporters! I am the proud owner of a Readynas Ultra 2. I ran out of space, and changed the Raid to expand instead of redundant. Before i made the changes, i took a config backup, of the ...
sonnesoftgun
Jan 17, 2012Aspirant
I will try and see if i can delete the addons.conf, if not i will need to re-install OS!
What is the problem about changing Raid mode? what else should i use the backup for?! if i can't use it after changing the raid?
Thank you, for a fast answer :)
