HarrisBerman
Oct 14, 2019Aspirant
Can't reset Admin password on RN422
I reset the firmware on my RN422 because I could no long sign in on the Admin account. The password was reset to "password". I then updated the Admin account for a new password. This worked. However,...
HarrisBerman
StephenB wrote:See if you can enable ssh, and then log in to ssh using root and the NAS admin password. If that works you could try changing the NAS admin password again with
# passwd admin
I enabled SSH, but trying to log on with root did not work. Perhaps I used an incorrect approach. I tried to use "root" as the userid in the logon request.
Oct 14, 2019Guru - Experienced User
HarrisBerman wrote:
# passwd adminI enabled SSH, but trying to log on with root did not work. Perhaps I used an incorrect approach. I tried to use "root" as the userid in the logon request.
That part is fine. Then you should have received a password prompt. Did you try entering the admin password there?
