jaholstein
Feb 11, 2018Guide
change Device Name
On my ATT router on the device list - My RN104 shows as
IPv4 Address / Name 192.168.1.10 / unknown28c68e353fc8
How can I get it to show
IPv4 Address / Name 192.168.1.10 / ReadyNAS104
Thanks, Jim
I think this is really an ATT router question. The NAS is advertising its hostname, but the ATT router isn't using that in it's attached device list.
Many routers will let you manually enter a device name, and will remember that name across reboots, etc - it is generally bound to the mac address of the device.
YES that is what I've found on the ATT community board.
The problem is that THIS SPECIFIC router does not allow a substitute name.
Manufacturer ARRIS
Model Number BGW210-700
