thebigerns
Dec 18, 2018Aspirant
Changing filename Case? ReadyNAS 424
Firmware 6.9.4
I have a share (SMB/AFS) that is used by MacOS (me) and a Windows 7 user. The Win 7 user can access the drive, create and delete content, change file/folder names but in instances involving changing just the case of a file’s name, the system will not allow it saying he does not have permissions. Is this just weird, or have I missed something? Is it fixable?
- SandsharkSensei
SMB and Windows are not case sensitive. I think he is just getting an odd message not really related to permissions. Windows just assumes that's the problem when the write fails.
Sometimes it helps to change a letter in the name to something else (changing the case as needed for the rest of the name). Then rename again, changing that letter back.
See if that is successful.
- thebigernsAspirant
Thanks for the reply and suggestion, I am grateful for your time and effort. I know it seems like a small issue, but still frustrating and distracting for collaboration. I will have to try and test this under Windows 10 maybe.
