belltt
Nov 26, 2013Aspirant
Changing from ReadyNAS Pro to RN31400
For various reasons we're looking to update the ReadyNAS Pros (2) we've been running on for the past five years. The capacity of the ReadyNAS Pro was always overkill for our purposes, so I'm looking a...
de_niro
Nov 26, 2013Guide
belltt wrote: For various reasons we're looking to update the ReadyNAS Pros (2) we've been running on for the past five years. The capacity of the ReadyNAS Pro was always overkill for our purposes, so I'm looking at the RN31400 as a replacement. I wanted to confirm that in making this change I would not be losing out on any functionality that I currently have with the ReadyNAS Pro and would not have with the 31400?
If not, will I gain any functionality?
to replace a RN314 is a good choice,I am not sure what kind of function you want,OS6 intergrated free Cloud service(Replicate,remote,Cloud portal) and a lot of add-ons
http://apps.readynas.com/pages/?page_id=9
belltt wrote: Is the 31400 loaded and compatible with the Egnyte NAS Cloud Add-On?
Yes,you can install this addon from the Frontview of OS6
