belltt
Nov 26, 2013Aspirant
Changing from ReadyNAS Pro to RN31400
For various reasons we're looking to update the ReadyNAS Pros (2) we've been running on for the past five years. The capacity of the ReadyNAS Pro was always overkill for our purposes, so I'm looking a...
Nov 27, 2013Guru - Experienced User
Are you using Frontview backup?
Frontview backup is essentially the same - you should be able to use the same settings with the OS6 NAS.
I don't use egynte or replicate, so I have no comments on them.
