belltt
Nov 26, 2013Aspirant
Changing from ReadyNAS Pro to RN31400
For various reasons we're looking to update the ReadyNAS Pros (2) we've been running on for the past five years. The capacity of the ReadyNAS Pro was always overkill for our purposes, so I'm looking a...
Nov 27, 2013Guru - Experienced User
Based on Chirpa's thread link, it appears that you can run secure backup jobs on the OS6 device, since you can upload the ssh key to your existing Pros. What you can't do at present is run the jobs on the Pro, since the upload function is missing on the OS6 side. Hopefully it is on their fix list, it is an obvious flaw.
Are the two PROs on the same network, or are these backups going over the internet? If they are on the same network, is there a particular reason you are concerned about backup security?
