juliachlotus
May 30, 2017Follower
Changing power siupplies in storage systems
Our client has a couple of Netgear 3200S and 4220S Storages installed. Can we change the 550W standard power supply with 700W? Is it possible to install additional 700W 12V power supplies in thes...
- May 30, 2017
Do you mean 3220 instead of 3200?
My 3200 and 4200V2 both came with 700W supplies. They use a standard SuperMicro chassis that uses their standard form factor for redundant supplies in a 2U chassis, an Ablecom PWS-702A-1R in this case. If your client's did not come with that, then they could certainly upgrade. Note that SuperMicro does not recommend you mix wattages, so you need to replace both.
I don't recognize the chassis manufacturer of the 4220..
Sandshark
May 30, 2017Sensei
