claynz
May 13, 2019Guide
Changing volume name of ReadyNAS RN314
Hi, I have factory reset my NAS unit and it created a Volume name of (data) can I change this?
Now when I open Network icon and click on my NAS it shows a folder called data and I can not access it...
Retired_Member
May 14, 2019Hi claynz, you wrote "...created a Volume name of (data) can I change this?"
Not that I know, sorry for bothering you. However, you might want to upvote a design change request already existing in the in the idea section to increase the probability, that Netgear is going to make this happen. Here is the link and kind regards
- claynzMay 14, 2019Guide
Thanks for the link
However when I bought this NAS unit 5 years ago I never saw a data folder, only happenned now since I upgraded the drives and factory reset, may due to firmware updates over the years
- StephenBMay 14, 2019Guru - Experienced User
You will see this folder if you are accessing the NAS using admin credentials.
From your screen shot, it looks like you are doing that (though perhaps with the wrong password for the NAS admin account).
The solution is not to use that credential. You can set the username you want to use in the Windows credential Manager.
- SandsharkMay 14, 2019Sensei
Even if you change it in SSH, the NAS UI won't recognize it.
I successfully changed a volume name, then removed and re-imported it with the new name; but only on a second volume in the NAS, Trying to do the same with the primary/only volume gave only grief.
My intent was to write a tutorial on how to do it if I was successful, so I tried a lot of ways without any successes.
