JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
Magilla
Apr 29, 2010Aspirant
I'm just on the verge of buying 4*ST32000542AS, and wondered if you'd had any subsequent problems.
I almost bought 4*WD20EARS as they're on the compatibility list, but I decided to read the forum before final purchase! Thank goodness I did.
It doesn't seem like the compatibility list provided by Netgear is overly reliable, so wanted to get 1st hand experiences before splashing out.
Are your Seagates performing as expected (apart form the click)?
Cheers
M
Cheers
M
- Aug 17, 2011Retired_Member
